kirkallen143
The threads pulled right out, talk about someone being pissed
After all these modifications I did for blow-thru on this holley, almost a years worth.
The thread is a 12-24, do you think there is enough meat to insert a heli-coil? If not, how close is the 1/4-20 thread compare to 12-24?
The 1/4-20 bolt might be too big to go thru the float bowl and/or metering block. I have not tried it yet, just venting here some.
Any suggestion are welcome, thanks.
Kirk
.After all these modifications I did for blow-thru on this holley, almost a years worth.
Kirk
