asmart
don't worry about hitting water jackets, I drilled and tapped for 3/8" course thread bolts, I plan on dyno tuning this setup then at a later date after the alum head is completed by the porter, doing the same thing, although it might be a month or so, seems nothing is fitting, well the motor mounts fit other then that, I have to remake the K frame brace, (my oil pan hits slightly) remake the trans X-member, (TKO mount is further back) not sure what to do with the trans mount (it is to high and makes the trans hit the floor pan) on the brite side all the work I did on the intake paid off, as Jim Carrie says it "Fits like a glove"
