Strong 200 rods
Dieseler":38ko1k45 said:
302 rod is only 5.09" long....
might work (too big rod journal diameter????) but would still need custom pistons...just by looking at a piston the wrist pin would be through the oil ring land.
From my understanding the journal diameter is fine, however the big end width is too narrow. But it's been mentioned that you could add material to the crank to get the rod gap back in order.
Pistons would probably need to be custom... I think a 1.21 pin height would be needed. Iapels come in a 1.24, close but I think cigarless. I'm wondering what the compression with a flattop 1.04 Iapel would be... I'm only looking for ~ 8:1
