All Small Six Piston choices
ActionYobbo
I am getting ready to build a draw through turbo 200. Only 6 to 8 pounds of boost.
Will be running a large log head and a buick v6 turbo setup.
What is the best pistons/brand to use on this mostly stock build?
Since you will using the large log head with 62cc combustion chambers, it would be best to use a flat top piston to keep the compression ratio from being too low.
The only piston that I know of is the Silv-o-lite 1185.
Those pistons are for the 2300 HSC 4 cylinder engine.
If you leave the pistons .030 in the hole, then the compression ratio will be 8.5 to 1.
If you zero deck the pistons the compression ratio will be 9 to 1.
