For a while I've wanted to convert away from my nos single barrel Autolite 1100 carb.
Last week I finally found the time to install the holley 5200 that Tom at Stovebolt sells. It installed easily enough, with the exception of the linkage. I have a '62 Ford Falcon with 200/6 from a 67 Mustang. On the throttle arm on the carb, I had to drill and mount another pivot knuckle more toward the center of the arm. In fact, right on the edge of it, about 1cm closer in than the stock position. This allows me to get 96% of the full throw of both barrels.
It runs super. After a week I checked my plugs and they are clear to mild toast color, and it idles fine except for the fact that I can't lower my idle under 650 before the idle speed screw disengages. But it's exactly where it needs to be in any event.
Last night I tested out the mileage on the highway in a controlled test: I drove out of Portland into the Columbia Gorge and drove exactly 100 miles at 65-70mph, and then returned for another 100 miles. I filled up and measured a disappointing 18mpg.
I used to get 20-24mpg.
I should also add that I have a C4 transmission and a Pertonix II setup with the accompanying flamethrower coil.
Timing is set to 14*.
The car runs super. Just thirsty.
Any thoughts on how I might get some of my mileage back?
