OK, I've done the searching, found the articles and read them, but I have just one question on the T-5 swap behind an 83 200ci (BB200?) using the 5.0l bell.
How far off are we talking here? Do I fill the holes and redrill? Offset and drill new between the old? The rest I get, but since I don't have both flywheels sitting here in front of me, I can't see what needs to be done.
I'm going to be using a 4 cyl T-5, so I'll need to go back and dig up that part number, or I suppose I could just make something to hold the 4 cyl bearing myself and press that into the crank.
Thanks!
BB200
The BB200 contains 2/3rds of a V8 block pattern. This engine came originally with a C5 automatic transmission. To install a manual tranny behind this motor, you must use a SBF bell housing, flywheel and clutch setup. The flywheel must be the 157T V8 flywheel, re-balanced from a 28 or 50oz imbalance to a zero imbalance. Also, because this block still has the 200 crank, the flywheel mounting pattern must be redrilled for the 6-cyl crank. I'd suggest drilling the new holes before having the flywheel balanced.
Thanks!
