Unfalconbelievable":fsbtb9xc said:
Ok, all this time i thought the turbo was a cheap chineese version of a garrett ..... its made by a company called XS POWER
It is still a cheap Chineese version of a Garrett.
They are sold by ssautochrome and a few others.
You can go to turbomustangs.com and do a search:
http://www.turbomustangs.com/forums/sea ... ?s=&action
=showresults&searchid=148745&sortby=lastpost&sortorder=descending
http://www.turbomustangs.com/forums/showthread.php?s=
&threadid=47825&highlight=ssautochrome
&threadid=42757&highlight=ssautochrome
http://www.honda-tech.com/zerothread?id=1097918
Any one heard of this company before?????
A lot of people have - I have not heard good things. They come from ssuatochrome
And the turbo does keep spinning faster and faster even once the wastegate is open because the engine requires more air the more it revs, say your wastegate opens up at 2800RPM and your turbo is pulling 30,000RPM, to keep boost at the same level when the engine is doing 5500RPM the turbo is probably doing 55,000RPM. The wastegate hovers between open and closed to keep the boost level at the desired PSI.
yes, that is true but don't get dramatic about it. If your wastegate is set at 2.0 (14.7 psi boost), then go up the map on the left to 2.0. then move to the right to where the amount of air (in lbs) is flowing. The sweeping lines with big numbers are turbine speed.
Here is an S-3, which is what I use to push 20 psi into my engine:
Alright, If I make full boost at 3000 (about where I am) then my engine flows 19 pounds of air per minute. go to the bottom, and look at where 20 pounds is, and go straight up to where 20psi should be (about 2.4 bar)
http://www.turbofast.com.au/tfcalc.html
Notice I a right up against the surge line, and turbo is spinning about 102,000 at that point.
As revs increase to 4700, I'm moving 30 lbs of air.
Go to the bottom, find 30 and go up to where 2.4 bar is.
See how the line for the turbine speed is curved down? At 30 lbs and at 2.4 bar, my turbine speed is now 106,000
Big whoopee deal. Shaft speed went up a whole total of 4,000 rpms.
SEE, that is why a map is so important. you can't just be pulling numbers out of your arse. You have to have the facts.
Even if I go to 5500 (34 pounds of air) the shaft speed is now only 116,000 so it doesn't go up THAT much.
And why on earth are you so worried about turbine shaft speed?
bye for now, I leave for Siberia in three hours..............
