crash-harris
Just happened to be watching Stacy David at work one day and they plugged a new product from MSD on the parts bin section of the show.
This -> http://www.summitracing.com/parts/msd-2900/overview/
It has 4 injectors and built in fuel rails in place of the float bolts and bolts in place of a 4 bbl carb. They specify that the injectors are 80 lb./hr. but I'm not 100% sure if they mean 80 lbs. each, or total across all 4 injectors.
These built-like-a-carb fuel injection throttle bodies with all the sensors (except O2) and the computer on them seem like great candidates for a simple blow-thru setup that would not in involve pressurizing a carb and blowing gas all over the place. And the MSD and Edelbrock systems come within-cab tuners (Edelbrock one comes with a wireless tablet
But my question is this. Would these be good candidates for the big sixer and a turbo in a blow-thru configuration? I know that the factory N/A multi-port EFI use six 14 lb./hr. injectors (84 lb./hr. total), so the replace-a-carb systems would have to supply more than 80 lb./hr. total, or is there something I'm missing on TBI theory? Don't really know much about throttle body injection other than the Dodge TBI system was a PITA to have on nearly anything.
Here's a list of similar available systems from Summit Racing (should be priced in order low-to-high) -> http://www.summitracing.com/search/depa ... ottle-body
