80Stang
Ok, just posting here the next engine that's going to power my daily driver, if you find something wrong just let me know:
Block '80 200
- decked to zero
- rods done
- ARP rod bolts
- Tempo flattop pistons +.030 overbore
- Comp Cams 260H
- Comp timing set
- balancing
Head '80 E0...
- new std valves with backcut
- new bronze guides
- porting done the best I could, pockets, exhausts all the way & valve unshrouding
- 60's rockers (adjustable)
- Comp valve springs
- milling, goal is 53cc chamber
- 2V adapter straight to the log
- Autolite 2100 1.14 or 1.21, or Holley 2300/350
My gasket is a Victor Rentz (0.045 compressed), this recipe should do CR 10:1.
Block '80 200
- decked to zero
- rods done
- ARP rod bolts
- Comp Cams 260H
- Comp timing set
- balancing
Head '80 E0...
- new bronze guides
