AzCoupe":1o8rthlh said:
I don't know how you all come to the conclusion that the DUI doesn't make more power than the DSII. Have any of you purchased one and dyno tested it verse the DSII? Or is this just a conclusion you make, merely becasue you think it doesn't? Do you have any data to back up what you state?
Between Classic Inlines and Performance Distributors, it has been dyno tested several times, and it has always made more power than the DSII. Nobody really understands why, but it does. I plan to do some dyno testing in the next couple of weeks, and will add the DUI to the testing just to prove it once more. We'll be dyno testing a stock 1V over the 2V via an adaptor, so dropping in a DUI will be no problem.
Again Mike, it's not a question of dynoing a car with a DSII and then dropping in a DUI. That will demonstrate that that particular DUI makes more power than that particular DSII, but says nothing about the relative merits of the two designs.
There needs to be much tighter control over all of the variables to be able to make that claim.
IE, what coil was used w/ the DSII, what wires, what ignition module, etc. Was the total advance the same in both tests? If you can control all of these things (and probably some I haven't thought of) and you still have one design performing better than the other, then there is still merely a suggestion that it is superior. In order to truly have confidence, one must do numerous tests on many different engines in different operating environments and look for trends. Unfortunately, this is not really feasible in this sort of circumstance. If you don't have a hypothesis as to why it should make more power, it is going to be very difficult to prove empirically that it
just does (short of testing it in 5-6 different cars, which can be cost prohibitive). There are so many variables involved that what makes more power in one setup can very well make less in another. We have all seen this happen. In the realm of automotive testing to ever prove that one item (of similar design/approach) makes more or less power than other is extremely difficult. It is much more reasonable to merely state that the DUI (in this case) is capable of making X power, independent of whatever the DSII can do. That is something you can actually prove.
There seems to be a trend developing here in that those of us who do system testing for a living expect a much more rigorous test approach than those who don't. I've seen way too many tests done that really appeared to show one thing, but after being subjected to a more rigorous test have shown something completely different. It's my job, and if I jump to conclusions and don't cover my bases, I look like a fool. The people I have to take MY test conclusions to ask very hard questions. Nothing more embarrassing than having your boss point out a huge hole in your test plan and why all of your data is invalid or at best incomplete.
My conclusion is based on a understanding of how the two systems operate. There is no reasonable expectation that one should make more power than the other. If you have test data that is to the contrary, then clearly there is something that one of us is missing. Either there was something about the testing that was done that wasn't well controlled, or there is something about the way it all works that I don't (we don't, because you yourself stated that no one really knows why it makes more power) understand.
Let's find out which of those two it is. I would be more than willing to work with you to develop a rigorous test plan that would at least offer us a suggestion as to which was the better performer (if any).
And Mike, it's not that I (or those that share my POV) are picking on you and your products necessarily. I have the exact same "complaints" about information posted by most automotive aftermarket companies. How many of us really believes that adding Clifford port divider is worth the HP they claim? Or how about a flowmaster muffler, etc.
The difference here is that you are actually responsive (Can you imagine a rep from Holley coming on a message board to defend their products? Yeah right...) - and that is awesome because it allows the information out there about your products to be much more accurate, which gives us all a higher confidence in them.
