notdone":30634v68 said:
Thanks for your replys. My mind goes a little faster than my typing, Is the carb plan a good idea (about 300.00) or go with an adapter and a different carb. Oh Dennis, I have your book and it's great stuff but, I think that's what's getting me in trouble, you make it sound so easy. I'am planning on swapping the 170 w/2speed with a 200 w/C4 in a 63 Falcon ranchero (2 speed tranny 's 2nd gear went out today). I bought a 79 Ford fairmount an stripped everything I could off it, got a tranny adapter. Could I keep the water pump and go with a electric pusher fan.
I swapped my old 170/manual for a later 200/manual, it's really straightforward.
http://fordsix.com/forum/viewtopic.php?t=31268 has details and pics.
Seriously, you could swap the 200 in, keeping everything (carb, water pump, generator, fan/pulleys) off the 170 except the ignition and maybe the exhaust manifold.
I don't know why you'd need a trans adapter, though. The trans should already be bolted to the engine? Unless you're talking about a C4 trans mount...
Wiring: the simplest/cheapest thing to do now is keep the '63 charging system (generator, right?) if it's working. If you want to upgrade, there are lots of options: Swap to a Ford alternator with an external regulator, swap to a Ford alternator with internal regulator, or swap to a 1-wire GM alternator. You can search the board for threads on them, or if you know which route you like let us know and we'll advise.
Ignition: I'd keep the ignition that's on the 200 as it is until you get the engine swap sorted out, then it's easy to recurve the dizzy yourself, all you need is a timing light, hand tools, and some patience.
Carbs: Personally, I
*HATE* parts-store "remanufactured" carbs, I haven't seen one in 10 years that wasn't a total abortion. If your 170 carb is ok, you can keep it (it'll be a little small, but it'll work for cruising around town). If you want to upgrade, the Pony carbs Autolite 1100 is a good but not-cheap option, or you could watch here for a deal on a decent Ford/Autolite 1-bbl, or maybe a 2-bbl.
