1) Even though I had no problem porting a set of heads for my dads 289 with his help 20 years ago, I seem to have forgotten all the important stuff.
2) 20,000rpm Electric Die Grinders will get hot enough to burn your hand.
3) Dont move the grinder so your on the debris exit side unless your wearing a dustmask over your nose(fortunately I was or I would be on a high iron diet about now)
4) Even at 6'4" and 350lbs I cant control the grinder to keep it from leaving chatter marks.
So a nice breezy low humidity 85 deg day so I setup outside on the ex hospital table and decide Im going to polish the combustion chamber.
After an hour I am not done with the first chamber, I still have pinholes in the cast iron and I have chatter marks intead of that nice even polished look.
I was planning to use the grinder to do all the cutting and material removal and then using either a Dremel and a some silicone rolls or one of those paint strippers to buff the combsution chamber smooth.
How do you guys get that smooth finish that looks like the chamber is baby butt smooth and even.
A few times the grinder escaped onto the deck surface to leave a trail that I can only hope will clean up when I get the head milled(should not be a problem). I thought the polishing would go alot quicker. Either that or I am being really cautious (yeah thats it)
I also laid back the combustion chamber wall away from the valves. Isnt it supposed to be 3/16" from edge of valve to edge of combustion chamber wall? The intake is about 1/4" from edge of valve to edge of combustion chamber wall.
I quit for today only because the electric grinder was getting to hot to hold and it takes too long for it to cool down. As in 1/2 hour or more and its still fairly warm to the touch.
Any pointers would be appreciated.
Thanks
