Thoughts on direct mounting 2v
66 Bronco
Hi all.
It seems that the main part of the direct mounting process is the furnace brazing. Now, it's not that I can't get it done here, I'm just tossing ideas. Iv'e worked with "liquid metal" from Wurth on several occations, tough as nails and you can even reinforce the stuff with fibre mats for the tougher jobs. Anyone tried that for the platform under the adapter? May be it can't survive the gasoline ? Also wondering, how much narrower is the opening in the log vs the combined diameter of the two holes in the carb base? I'm shooting for 20, 30 % diffrence?
Hjörleifur.
66, some have used both studs and epoxy to hold the base down on the log. as for hp increase check the dyno section on Classicinlines.com if you haven't already.
