Will do!"...seen enough to know..."
good 4 U. Dont stop ur reserch yet.
Keep it up'n U will no.
Dont listen to me, find out 4 ur self ~
I admire what you are trying to do, but I would (well intendedly) suggest that 300 Hp for this engine is a lofty number. You can get there - but it will be expensive to do so.I'm hoping to get at least 300hp within my current budget.
I'm considering a budget turbo build. From what I have read it should double my Hp.I admire what you are trying to do, but I would (well intendedly) suggest that 300 Hp for this engine is a lofty number. You can get there - but it will be expensive to do so.
It takes 15 to 17 lbs of boost to double the engines hp.I'm considering a budget turbo build. From what I have read it should double my Hp.
That’s enough to get a set of forged pistons and machine the block to install them.I was hoping for less than $1,000 using scrapped parts.
Well, I've found some nice budget turbo builds on here that I would use as references. I can probably port out the head myself and I would fabricate the exhaust manifold.That’s enough to get a set of forged pistons and machine the block to install them.
You would need the following:
Turbocharger
Blow off valve
Waste gate
Turbocharger exhaust manifold
Intake manifold
Intercooler
A blow through carburetor or EFI
High pressure fuel system
Boost referenced fuel pressure regulator
Modify and rebuild the head
There is more but I’m stopping here
