Gene 64 2dr
I may have a timing issue here. I a rookie as far as timing go. I’ve read plenty of articles and understand the basics but not quite sure what numbers I should be seeing with my setup.
Back ground: DUI, 268/274 110 cam, 6 to 1 roller tip rockers, Offy 3x1 weber, manual Trans
The cam was originally advanced 4 degrees but has been returned to straight up, ( noticed a very small mark on top of one piston that looked like a valve may have just slightly tap it)
Here are the numbers I get:
Timing @ 900 rpm
12 degrees vac disconnected and plugged
29 degrees vac line connected
Timing@ 3K
31 degrees vac disconnected and plugged
44 degrees vac line connected
Vac@ idle
8”
Vac@ 3.5K
14” (max vac that can be obtained)
Symptoms: when initial timing set @ 12 degrees (14 better) normal driving is great, nice and smooth acceleration to 3K. However if you stand on it at around 3.5K it gets a little rough and around 4K to 5K starts to back fire.
If the timing is set to 10 degrees the acceleration is great and pulls real strong all the way above 5K. At a steady speed however you get a slight bucking that’s not right.
Anybody have any thoughts on this.
Thanks
Gene
Timing @ 900 rpm
Timing@ 3K
Vac@ idle
8”
Vac@ 3.5K
Thanks
Gene
