I've been reading. A LOT of reading lately on timing, advance curves, total timing, All in timing, Initial timing, Static timing, and so on. I read all the posts here that had to do with Timing. If you did a search in MSN on Ignition Timing Curves you would find over 2100 articles alone. This all got started for me with Corellion's post on Stovebolt and his problem. I soon found out that there was several problems (and in some cases non problems) that were do to definitions. I'm no expert at this, my main issues were with the effect or causes of overheating do to the timing, cooling system and carburetion changes I had made. I'm working backwards on this since I made all these changes, including several others, and ended up with a motor running 50% cooler and wanted to figure out why. So to this end I looked hard at the timing and distributor as a possible reason. While reading these articles I reread several major posts and wanted to clarify some issues and hopefully get conformation as well as input to help others that are as easily confused as I am.
DEFENISIONS:
INITIAL TIMING / STATIC TIMING (same thing)
The starting point that is specified in the manual for the timing. This is based on a stock motor in good condition with no modifications. It has been determined that 12° to 14° is a good starting point for a "modified" engine and we will use 14° as an example. Disconnect the vacuum line from the carb and cap off the carb port. Another MAJOR factor here is the RPM's during this test. The motor MUST be idling below (as low as possible) 800 RPM or there's a chance that the Mechanical (Centrifugal) Advance has kicked in and your numbers would be off from the get go. Take a reading and set the timing to 14°.
MECHANICAL / CENTRIFICAL TIMING (same thing)
The advance function of the distributor utilizing springs and weights to advance the timing in relationship to the RPM's. The higher the RPM's the more advanced the timing. To a point, there is a stop (can be adjusted or modified) were you can increase the RPM's but the timing advance stops. Also may be related to the phrase "hitting the wall".
This is also the starting point to get the Total Advance numbers. With the timing light still connected and the vacuum line still disconnected, pen and paper handy we start to increase the RPM's by 500 and note the advance points on a dial back timing light. Note: I've read a lot about degreeing the balancer and adding tape and marking off additional degrees and determined there's to many variables I could screw this up so buy a good dial back. So before you increase the RPM's set the timing mark from the reading of 14° to 0° on the dial. As you increase the timing note the advance numbers at each 500 RPM increments up to 3000 RPM's or until you have 2 points that no increase is noted. I then decrease the RPM's until I see a decrease in the advance and know where the maximum advance and RPM's occurs. Note this also, typically this should be around 2800 RPM's at 24° on the dial back. 24° is your Mechanical advance.
TOTAL ADVANCE
Initial Timing + Mechanical Timing = TOTAL TIMING
Now this is where the fun begins. Some will say the Total should include the vacuum advance connected as well but think about it, the vacuum advance is only at idle or light loads to increase gas mileage in most cases. It's a variable and is vacuum only dependent. If this were the case why wouldn't we add (subtract) any retarding devices to this equation? The Total Advance tells us what the advance is under WOT, something performance nuts all want to excel at and lower the ET's. Were this occurs is adjustable by springs, weights and stop points modified in the distributor. The curve (according to what I've read) should be smooth from 1000 RPM to 2800 RPM. (Your engine may very) For this example the Total Advance is 14° + 24° = 38°. Several have referred to 38° as the correct number for Total Advance. If anything we should set a standard one way or the other for this definition so as to not confuse this complicated issue.
VACUMN ADVANCE
An advance state created when suction is applied to the distributor vacuum diaphragm causing the distributor to advance when at idle or under light loading such as cruising in high transmission gears at lower RPM's. A number of people have suggested disconnecting the Vacuum for better performance and I've read this as well. So if your basically going to start your car, point it in a straight line, floor it for 14 or so seconds, and then stop, I would also. If you’re driving it around town and paying over $2.00 a gallon hook it up.
Now we're still at idle (as low as it will still run), the vacuum line is still plugged, and we're reading 14° on the Timing light. Dial back to 0° and hook the vacuum line up. Check the reading on the timing light; it's probably around 15°. This is adjustable when an adjustable vacuum advance canister is installed on the distributor; normally ID'd when the canister has what looks like a large hex head at the vacuum nipple. By inserting a 3/16" allen wrench into the nipple you can increase or decrease the amount of advance. 15° seems to be the max you want under typical conditions.
ALL IN TIMING (I think this is what it's suppose to be called)
All in Timing is with everything added up and again from what I've seen and read is a total of everything, your initial, mechanical, and the vacuum advances. This number seems to be just a " Total Not to Exceed number which I'm not really sure is obtainable under normal driving conditions.
At idle you don't have Mechanical advance
At WOT you don't have Vacuum advance
At Partial you have a combo of the 2. I guess if you were at WOT, min. RPM's and going up hill like a bat outa hell?? I'm open to suggestions.
From what I've seen 55° is the top number.
Well there is a lot of good advice out there on tuning the Dizzy as well as conflicting advice. My thought here again was if I was confused then maybe someone else was also. Hopefully this will be added upon as well as any errors or omissions corrected to further clear the subject up. ALL responses are welcome.
Steve
DEFENISIONS:
TOTAL ADVANCE
VACUMN ADVANCE
Steve
