Earlier this year, I installed a 1980 200 I-6 engine with AC compressor in my 62 Falcon wagon. To find enough radiator clearence I had to switch to an early short water pump and early two groove WP pulley. To retain the late model 3 groove bottom balancer pully to drive the AC, I mated the early WP and pully with custom built WP spacer to realign the belts. The early WP pulley is larger dia. The larger dia. WP pulley combined with the larger dia. late ballancer pulley, caused the two pulleys to kiss while rotating. To cure this, I ground a little bit off the edges of both pulleys until they no longer interfered. Long story short is that in the process, I lost my timing mark (groove) on the balancer pulley. Any ideas on a easy way to refind this important spot so that I can file in a new groove?
It all works great except that my only method for timing is the ear method. I know, I know, I should of thought of this before all of the timing mark was ground away. A simple grease pencil mark would have worked wonders. But you know how it is..... a late hour in the garage working on a project that is taking way longer than expected. The shade tree lamment
Thanks in advance,
Mike A
Thanks in advance,
Mike A
