I am moving this to it's own post, I had added it to the bottom of another post and I think it got overlooked...
I am running a DII setup, and I set the engine on -10BTDC that put the rotor right on the number one position... I was attempting to do a static timing making sure the rotor tang was inline with the magnetic post and according to the book the rotor should be between the rivets for correct advance... mine lines up right with the pickup. I have to rotate the dizzy towards the drivers fender to get the rotor between the rivets. then the tang does not line up.... does it sound like I am one tooth off...? does to me.. I am thinking I need to be one more tooth counterclockwise... I think I am on number one at -10bBTDC... am I making sense to someone? the thing is that little rotation from 0 to -10 does not move the rotor that much at all? it is pretty close to number one in that whole range.. so the can position is the major factor right?
(Still learning)
Always
(Still learning)
Always
