would there be in any benifit in fitting 3 2ltr pinto carbs on an alloy head 250? not entirely sure if i want an every day car or a special sunday drives car.
xtaxi":2r8el78f said:The more carbs you have, the better calibrated they must be, and the more sensitive to bad back yard mods.
There is no way six carbs is an easy option. The Mikuni set-up Jack Clooins was running on his X-flow was very hard to tune. That is the only option for a six carb set-up, any thing else won't work. Options like the ancient Amal, Lectron, or more modern Kehien or other motorcylce carb is fine, but you have to know how to patiently dial in the fuel and air right througout the rev range without holing a piston through a lean patch or goingover rich and wetting cylinder bores and creating significant hard starting.
The worst thing is that six carbs isn't just harder than a triple carb set-up. With needle combinations and jets and air correctors, there is 50 times the work of setting up three Webers when using a bucnh of six motorcylce carbs. There are something like 2500 needle combinations in the Mikuni carbs alone, but only about 100 valid SU needles for a set of 2" HS8's. You can custom make needle settings easily, but the Mikunis are tiny and need much more effort. Cost is an issue. Get the wrong basic size, and it'll never work well for the cam and rev range of our sixes.
There is just no basic information avaliable to make even an educated guess on what the ideal jetting is. The carbs run on about 0.5 psi of fuel pressure from a header tank, so the stock 6 psi fuel pump with kill the delicate calibration and throw another curve ball on getting it sorted. More money to spend.
We've got to face facts. Even the stock single carb is a problem to tune for 90% of us, and it takes a while to gain the skills.
Scaling up the difficulty 6 to 50 times isn't smart.
Carbs like triple set-ups (Webers DCOE,DHLA Dell Orto's and espically SU's and Stromberg CD175's), these are simplicity itself, and there are basic jeeting starts and information to draw on to make it work.
If you are prepared to grab an old engine, and experiement at the speedway or in a bush bus, you could make six of them work okay if you had time and were able to invest in a couple of wide angle oxygen sensors or pyrometers. You could invest in a syncrotester and colortune, and adjust the basic mixtures, then set up the mixtures more accurately on a chassis dyno.
There is no short -cut.
