Hi. I have a 250 with an RBS carburetor, 800 idle, 12° timing, ported advance, manual choke. Cold start is fine I give it a couple of pumps and it starts right up and hold my foot on the gas at about 10-1100 rpm to warm, push choke in, fine, idles ok drives ok, runs cool... If I park and then go to start again after a while , and now in warm weather, will only start with gas pedal fully depressed and held down and then turns over after a few tries, but with high rpm which I immediately bring down and again everything is fine. Carburetor seems to want a lot of air, iidle air mixture 3+ turns out, vacuum steady at about 19in. So any advice on restarts in warm weather, or maybe all that I have said seems normal, would be greatly appreciated. Thanks.
