LameHoof65
I have read that when you go turbo, you should keep your compression somewhat low say around 8.5 or even lower? And also that camming up for a turbo can actually give you poorer performance regarding exhaust pulse and timing issues....is this true?? The reason is, I am seriously considering the turbocharging route....and it sounds like though I may spend more money in say forged vs. cast pistons and high performance valves...I won't have to worry about milling the head to that all important compression level necessary for other types of performance builds.. As well should I worry about getting the higher lift from say a 1.6 or 65 roller rocker setup?
