Hi Guys and Gals,
I am planning on adding a blow-through twin turbo set-up to a 250 inline six and dropping it in my 68 Stang. It'll be a street machine, low-mid range power is more important that top end and i want a fast spool. I'd like to run 10-12psi if possible.
I've doing some calculations and comparing these to some compressor maps, but i'm not really sure whether i'm doing it right or where my results should fall on the maps. I was hoping someone here might be able to offer some advice....
Here are some maps i prepared earlier....
Vertical lines are 2000-6000rpm, in 1000rpm steps, calculated at 12psi.
Do you think any of these would be good for a twin turbo set-up? Too big or too small?
Any advice greatly received!
Nathan
Nathan
