Comments? .. DS-II mods for a simple low boost carb'd turbo setup ... :
Following some forum threads , I opened up a DS-II to modify for more effective timing of the turbocharged 250 Maverick . I was going to plot/weld the advance plate to limit maximum advance. I was surprised to find a " 13 R " slot on the Centrifugal Advance plate. The 'twice at crank ' maximum mechanical advance of 13X2 = 26 Degrees BTDC (about max rec'd for 93 pump gas and @ 10PSI boost ). ... With initial set at @ 2 Degrees BTDC, manifold vac to the distributor should add Vacuum Advance at non-boost cruise and as manifold vac turns to boost with no vac' advance for a maximum mechanical 28 degrees ... sounds simple enough ... .
haev fun
haev fun
