Drives a 5
I need some help with my Holley 2300. After I swapped from the one barrel it ran great for quite a while, all I had to do was a jet change and some accel. pump arm adjustments. A while ago though, I went out and it just started idling rough (surging) and cold starting & running took a dive. I can't figure out what caused this as I hadn't made any changes. I took the carb apart, cleaned it, readjusted idle stop and mixture screws and the idle is ok, but startup is much worse than it used to be. I have to start it 3 or 4 times to get it to idle and not die and it wants to die when I accelerate. It does run pretty normal once it's warmed up though. Anyone have ideas on what to check? It's my daily driver so thanks for any help!
