There are no major points in the Ford 200, either four bearing or seven. People race the 170 to 280 hp, and 7500 rpm without failure.
The Argentina Ford racers run seven bearing short stroke 183 cube engines to 9500 rpm and 380 hp.
Mathematically, there are small vibration periods in the working rpm range, but in practice, the engine isn't afflicted due to its large 2.124" crank pins and low reciprocating weight. The 10 counterweight crank isn't wonderful, but with a better than stock 1993 EF Falcon balancer, you wont have any issues.
In Australia, our same bore spacing, and smaller crank journal. larger main bearing 3.625" bore, 3.25" stroke, 5.25" rod and 1.61:1 rod ratio 202 General Motors Holden engines had two torsional vibration periods, one at 4500 and another at 5300, and with a standard vibration dampener, it shock everything loose.
The early solution for the early 179 and 186 engines with 3" stroke and the short stroke engines an 1.75:1 rod to stroke ratio was to go for the 13 pound heavier 149 steel crankshaft over the later nodular iron one. When the engine got stroked to 202 cubes, it got a more pronounced vibration, much more noticeable, at the same rpm points. It was then that Holden went to a fully counter weighted 12 counterweight nodular iron crank, which was 13 pound heavier, and pushed the torsional vibration period up above 7500 rpm, where most racers wouldn't run into it. Adding an inserted down to Holden 202 size 1.25" spigot 350 Chevy balancer was the early solution before the advent of the 12 counterweight crank.
On the big 250, the US engineers just went to a small block Ford/Big Six style 1.375 spigot balancer. In Australian 200/250 9.38"tall deck and 9.22" medium deck 3.2/3.9/4.0 OHC sixes, they stayed with the 1.245" spigot, and played around with balancer, the counterweights went to 12 for some models, then they downgraded back to a 10 counterweight crank, but with bigger main bearing and longer rods. So Ford Oz was working the cost benefit of engineering changes.
I'd personally not even bother, but an EF Falcon balancer should help pull out any vibrations from the crank.
