What would be the problem of using the oil through lifters that are for a SMALL BLOCK FORD on a solid pushrod regular rocker oiling shaft design, with the future thought of going to the 1.65 full roller rocker arms which uses pushrod oiling. The solid ball end of the solid pushrod would block the oil flow from escaping from the oil hole in the pushrod cup.
Then when you wanted to update to the 1.65 full roller rockers you already have the oil through lifter installed & broken in on the camshaft that you are using. That not only saves you from at the least from removing the cylinder head to install the oil through lifters. Installing another lifter on a camshaft is not the best thing, because the lifters are mated to each camshaft lobe from initial installation after the initial breakin.
Mike,az coupe you sell both sets & said you were going to discontinue the regular 1.6 roller tip rocker setup. Has any body tried this, at most you would get a little more oiling at the pushrod end at the lifter.
Is there any difference in length between the 2 pushrods?
Is there any difference from the base of each type of lifter to the pushrod seat?
LETS hear it guys. William
