I've never had to groove a lifter bore, nor have I ever wiped a cam.
The main problem for camshaft issues is improper camshaft alignment, lifter bore geometry, run in procedure and some oils.
Short block.
- Hone lifter bores and ensure they are straight with a light crosshatch. Ensure they are not worn and polished from wear as it cause other issues.
- Measure lifter and bores, as like everything the tolerances vary.
- Ensure lifters are free to rotate in the bores and do not have any tight spots (if you follow the first 2 steps this is almost guaranteed)
- Clean off any assembly oil from the cam or lifters and ensure they lobes and lifter faces are clean of any oil. Do not skip this step oil will make the break in lube/moly lube slide straight off.
- Apply engine assembly lube to the bearing journals and break in/ moly lube to the lobes and lifter face.
- When you install the camshaft make sure that the lifter isn't centered on the lobe. Flat tappet cam lobes are not parallel, they have a taper so the lifter turns in the bore.
Valve Springs
- Ensure you only have about 100lb seat pressure for your run in, that normally means pulling the inner spring.
Run in
- Do not crank your engine to get oil pressure up before start up, otherwise you just wipe the cam lube off the face of the lifter before it has a chance to start the run in procedure.
- Run in the cam before anything else, don't play around with tuning the carb or timing just do the cam first, bring the revs up and follow the manufactures run in procedure.
- Drain your oil straight after run in while hot.
- Put correct valve springs setup for the cam in
- Double check your valve lash.
Once you have done all that, and as long as it was all assembled correctly, you can now do what ever you like and not have to worry about that flat tappet again.
