I am trying to go through a list of items that may be causing my car to die when I stop at a light or intersection. Six starts to travel 12 miles.
Here is a list of what I think may be causing the motor to die:
Incorrect vacuum at the dizzy.
Timing may be off.
Engine idle speed may be too low/high. (set at 1300 +/-)
Idle jet may be too small/big.
Ok, From my understanding, the regulated port on my Weber Carb is supposed be connected to my dizzy. I have noticed that if I disconnect the vacuum hose at the dizzy, the RPMs drop a little, but it seems that my stalling problem goes away. I will try my little test again over the weekend, but last weekend when I was fiddle farting around with it, that is what happened. What could be causing this?
Thanks for any help.
Ted
Timing may be off.
Ted
