Shakey Bender
Active member
Hi all. A little background on the issues i'm having is in order I think. To start my fuel tank is original and has been giving me a little more than just gas. That said, I regularly change fuel filters (the big clear plastic paper element type). The issue I am having is when I really get on it I regularly run the bowl dry in the carb. There is air in the filter and it never gets much more than half full. Originally I had it between the pump and the carb. Now I have it between the hard line and the pump.
Sorry this is getting so long winded. But someone will probably ask these questions plus a few I'm not thinking of.
I tried this setup to eliminate the silt and garbage I found when I disassembled the pump and cleaned it out. Is a stock cam driven pump on a fresh motor better at pushing gas thru a filter or pulling? The pump is new and the cam lobe shows no wear. Some other things I have done, new hard line soft line and clamps removed the p/u filter cleaned out the carb and so forth.
