Wanted 223 Rocker Arm Assembly
Hello, i am locking for Rocker Arm assembly or Parrts for the Rocker Arm line.of my 1957 Ford Fairlane.The Nr.1&2 Arm Shaft Support Blocks are brocken.Any Help will be great! Thank you
I have an Rocker Arm Assembly from a 1961 223 that I could sell you, but I am unsure if the support blocks are the same. I will get you a picture as soon as I can.
Hello. I believe the 61 will fit.but i like to see a few pictures if possible.if your are not able to post pictures here so please email me: Mitch.witte @ t- online.de. thank you
Hi cadillac52 and welcome to the ford Six forum. If you still have all the OEM 1957 early top end parts: IE a 1954 to 1960 Head, with the stock early Rocker Arm Assembly, and an early Valve Cover. the later 1961 to 1964 223 Rocker Arm Assembly though they will bolt onto the older Heads, yet there won't be a way to attach the early valve cover to those later Rocker Stands. Good luck in your hunt
