I had posted before about a possible timing set causing engine noise and the general consensus was valve adjustment. Well, I began pulling things apart to change some things on the engine and lo and behold, the chain is more than shot. I am able to rotate the crank the full range of the timing marks and then some without any movement in the dizzy or upper valve train!!! Looks like Mike will get some of my money this week for a double roller
