So I went and completed a Duraspark distributor swap into my 56 F100 223. I am using an hei ignition module for spark control and an accel super coil (for now, looking for a tfi unit). I thought I had this thing all set and went to fire it up but…
The only way I get it to start is by giving some gas and then it dies. Won’t idle. At first it sounded like an intermittent misfire and the timing light strobe was erratic. Went through my new wiring and found some potential loose connections that I have now fixed. But still, won’t fire up without a small pump of the gas pedal. Then won’t run without a bit of foot feed.
I swapped in a Clifford intake with Weber carb a while ago ( before distributor swap). I thought maybe I had dirty fuel issues plugging the carb (dirt in the bowl) so went ahead and pulled that apart to clean it. Also replaced the factory original rusty steel fuel lines. I now have an electric fuel pump running fuel from a new tank in the back.
I have confirmed fire order and plug wires are right and had my FIL over to rotate the distributor while running all to no avail.
We’ve tried everything we can think of short of compression test. I even set the valve lash. Truck hasn’t run in 4 years while it was being restored. Anyone else have ideas?
