well if you have a cylinder with good compression that is full of gas it has an ignition problem on that cylinder. Perhaps just fouled a plug and it never cleared up. why did it foul?? Perkaps just bad luck--maybe a bad or loose plug wire--maybe 2 plug wires crossed up (firing order 153624) Maybe a choke malfunction.
Dieing under load could be a few different things such as bad vac adv. diaphram-(easy to check; timing mark should walk around pully counterclockwise when reved);crossed plug wires (firing order mixup) ;partialy clogged main jet(common after carb work, a little flake of rust or rubber gas line gets in there); A bad condensor on the points ( a hard thing to check but they are cheap); A vac leak--(torn carb base gasket or vac line disconnected). Choke malfunctioning-(closeing up when throttle is opened caused by linkage or spring problems). Points gap incorrect (usually too small a gap and it won't open enough for hi rpm); Worn out plug/ coil wires(usually a very neglected item). And of course a fouled plug or two. or incorrect plug gap.
