If you are using the regular ds2 cap, the one with the male ends that clips on, just get a set of wires for any car with a 200(or whatever engine you have) after 1975. You should have at least 2 choices at most parts stores, a $25ish one and a better one that could be more in the $50 and up range. I went with the cheapos because I still dont have my oil leaks stopped and I didnt want to wreck a good set. The 6's are fairly easy because they are all on the same side with few things in the way so the length is not critical. The set will come with the short coil wire. GM hei ones may fit but wont have the coil wire and IIRC some of the GM 6's had 45* boots which you dont need on the fords.
