WHICH DISTRIBUTOR SHOULD I USE
ponyrider200
Active member
I have a 66 Mustang with the 200 ci six. This winter I completely overhauled the engine. This included the better cam from Comp Cams, and milling the head to regain the 9.0 to 1 compression. Since my replacement Holley carb with a D0 date code was shot, I am replacing it with a Carter RBS that has 215 cfm. This carb does not have the spark control valve, so I need to change the distributor too. I don't want to use the DUI or Dura spark. Is there an OEM distributor I can use that has single vacuum advance AND mechanical advance?
Thanks for the help. you guys rule.
Why not? I don't know of any other options. Mallory made a replacement, IIRC.
Yes there was a dual vacuum dizzy in the '70's, but it was a duraspark.
Thanks for the reply Jackfish. I am trying to keep as close to the stock look as possible. I thought I was going to be OK with a '68-'70 single advance distributor, but none of the stock dizzys have centrifigal advance. I was hoping someone knew of a dizzy I could use that offered both vacuum and mechanical advance.
All the 67 and later distributors have centrifugal advance. The 66 and earlier loadomatics do not.
You can't see the advance mechanism; it's under the point plate. It looks like this if you pull the breaker plate off.
With the Duraspark 2 set up, and the choke set properly (finally), my 67 starts up as easily as my 05 Jeep GC.
Once I decided that keeping my car original wasn't much fun, I decided to upgrade a few things, and I am very happy with the DII ignition.
MPGmustang":1j7sko0z said:
IIRC all OEM distributors 67+ are "duraspark"...
8) the duraspark distributor did not make the scene until the mid 70s(1974 i think).
Howdy Pony and All:
If your goal is to maintain a stock appearance then FYI- FoMoCo used a point type distributor with both centrifugal and vacuum advance beginning in the 1968 model year. It was used in conjunction with a downsized 1100 which had no SCV but a ported vacuum source for the "New" distributor. Some of these distributors used a vacuum cannister with both vacuum advance and retard. If you can find one with only vacuum advance that will be cleaner in appearance. If you have to use the advance/retard cannister just don't use the inner nipple on the cannister. Don't plug it either.
The first generation of the DuraSpark system began to appear sometime in the '72 model year (IIRC). It is a pointless distributor with a remote module, and a specific coil. It has a small black cap and early type spark plug wires. It used both vacuum and centrifugal advance. If stock appearing is your goal along with better performance and lower maintainance, then this is the way to go. I would suggust that you invest in some better spark plug wires as the OEM carbon impregnated core wires are prone to leaking and shorting. Spiral wound solid core wires are the way to go. Some shorting inside the small, stock appearing distributor cap is also possible, so keep in clean.
The next and last generation of the DuraSpark system was called the DuraSpark II. Clever huh? It begin to appear in the 1974 model year and remained until the distributor ignitions were replaced. The biggest difference between the DuraSpark and the DuraSpark II was the size of the distributor cap and larger diameter spark plug wires. There were also some specific changes to the module over time and applications, but that's another story.
Both the '68 & '69 point distributors and the early DuraSpark will be compatible with your RBS carb. What head are you using. FYI- the carb bore on the '66 head will have to be modified to allow the butterfly valve of the RBS to open. If stock appearing is the goal, I'd recommend the Early DuraSpark system. Open the plug gaps to .045" or .050" and never have to adjust the points again. Keep us posted on your progress.
Adios, david
Thank you for all of your replies. CZLN6 I appreciate your detail response. I did not know about the early Duraspark dizzy. This is the route I will take.
Lou
In 1973-74 there was also a small cap on the Duraspark II. It can replace the large cap on the Durapsark II and uses the old style plug wires.
Powerband,
Thanks for the input. I may end up going that route if I can't find the distributor I am looking for.
Another question I have is what the distributor driveshaft size is? Do you know if it is 5/16, the same as the small block V8?
