We have a 78 200 in my son's 66 Mustang. He started using water internally with white smoke coming out from the breather cap and from the exhaust. Tuesday night we changed his head out to a rebuilt 67 head that I had. Water is holding fine. Did see that we had an oil leak on the previous head gasket, so I'm thinking that either the head was warped, or gasket was bad.
At any rate, everything is operating fine , except that he is blowing oil out of the breather. We're using the 78 valve cover with the breather in the back. Also getting smoke from the breather cap when we rev the engine. PCV valve seems fine. I'm stumped. Is a new breather cap, though it does not seem to seal that well against the valve cover. Help! As I stated, the water is doing fine. No sign of using any, and no sign of water in the oil. Also, no smoke from the exhaust. Exhaust fumes smell normal and is clear. I need suggestions.
