A stock or slightly modified 200 six only needs a 40 mm turbocharger which generally does not come with a twin scroll turbine housing because of the small size.Mr. Muller do you think a divided turbine would be worth doing or just join them together and do open?
That’s sweet!Many six turbo headers put the turbo around the alternator/battery location but some six cyl imports' turbos are located down and back a bit. As mentioned a smaller turbo will provide adequate performance. Crossing engine also mentioned or a J-pipe type path after Y to the turbo may be considered or necessary, definitely consider an AFR gauge bung in exhaust after the turbo.
Buick/Garrett T3 Draw-thru setup on 250 Maverick - stock manifold and J pipe to turbo
