Will the ARP studs work on the log head?
65fback
I have to replace the head gasket. I'm getting a little weepage on both sides of the block. Since I'm replacing the gasket anyways, should I spring for the ARP studs? Will they work just as well on the log head or is there going to be enough difference in height that they won't be workable?
YES-YES, just make sure the stud on the RF is shortened to clear the water pump impeller.
Also since this stud goes into the water jacket make sure you put sealer on that stud just like you would on a SBC.
