I have a question about factory pistons & compression in the 200 and 250 and hope I can ask it clearly because the numbers out there are confusing. I read the following in FAQ:
viewtopic.php?t=1027
But it leaves open the questions:
1. If the 200cid had 9.2cr with a 52cc or so head, what happened in 1969 when its head went to 62cc? That would take the compression down to 8.2 unless something else changed - like a flattop piston instead of the 6.5cc dish.
And yet, most of the specs I see still show torque of 190ftlb just like the 9.2cr pre-1969 version, and compression does not drop to 8.3 until 1972 (though the numbers here show some scatter from 1969-1971). This implies the compression was still "up there" from 1969-71 even though the 200cid was running a 62cc head. What was done to keep the compression up?
2. Similar question for the 250cid. With its 6.5cc dish piston, .123" deck clearance (from the Classic Inlines site, and it jives with the deck height of 9.469"), and 62cc head, I get compression of about 8.25, close enough to the 1972-up rating. But in 1969-71, the 250 was rated at 9.0cr. Was that a bogus number, and if not, then again, how did Ford do this with a 62cc head and 6.5cc piston dish?
I figured if anybody knows this history it will be here!
