Hey guys
I'm planning on doing some work to my engine, at the moment its in pretty good condition, uses absolutely no oil and water, has good compression etc. Now what I was thinking of, was putting in a Wade 877 Camshaft, here are the specs on it.
877 Ex .293
In .293 70-32
31-72 212
212 Hyd
Hyd .507
.507 110 Needs springs, good midrange
2000 - 5500
Now, I also plan to do new lifters, Heavy duty valve springs, and a new timing chain kit. Obviously after all this work has been done I will get it dyno tuned so as that I'm getting maximum benefit out of the cam work.
I plan to keep the standard 34adm weber, possibly rejet it if needed.
What are your guys thoughts on this? Do you think the bottom end will handle this fine? Howmuch power would you expect at the wheels for this setup? What other problems could I encounter with this work?
The car I'm planning to do this work to is an XF Ute, running on leaded. Currently has a 3.23 Diff ratio, 4 speed, Genie Extractors & Lukey 2.25" Exhaust.
Look forward to your comments, Cheers.
877 Ex .293
In .293 70-32
31-72 212
212 Hyd
Hyd .507
2000 - 5500
