early ford fan
on a1962 170 harmonic ballencer other than using a piston stop?
			Do you have a dial indicator?early ford fan":2ix8sfl2 said:on a1962 170 harmonic ballencer other than using a piston stop?
I have wondered that as well; thus far I have never heard of one slipping only a small amount, the typical number seems to be well in excess of 30º, sometimes far more. Think about it: those things are made of metal with a rubber ring vulcanized in the middle; when it actually lets loose it probably will travel some distance, sorta like a slingshot.fordconvert":1olp50yz said:.....How far do balancers slip? Do they sometimes just move a degree or two? .....
Yes.fordconvert":q2u7qgqy said:I wonder if perhaps the reason people think you can check it which these basic 'eyeball' methods is that they never slip a few degrees. If they always move say 30 or more then it would be easy to see that by eye.
66 Fastback":5xrgoq28 said:I think if it has slipped only a few degrees, you probably are not going to have any drivability/tuning problems that would concern you enough to actually check for the slipped balancer.
 Lazy JW":5xrgoq28 said:he installed the timing gears about 90º off and SWORE that he didn't even touch them (he wasn't supposed to remove them at all, but that's another story).
 but seriously, that's why I like combining the 'eyeballed' piston pinnacle while observing the valves...get's pretty close, but yes still margin of error.
 but seriously, that's why I like combining the 'eyeballed' piston pinnacle while observing the valves...get's pretty close, but yes still margin of error. ...was DD'ing the ol girl and working nights, battling a leaky top radiator tank in the winter (so I just kept putting it off and adding water).  Leaned the mix out enough that one of our rare TX freezes froze up all the water in the head.  Jumped in, hit the key and WHAP!  BLAM! BLAM!  Seperated the the pulley right off the crank...water pump didn't budge a bit (frozen solid).  Could still pick up used balancers cheap then (12 or so years ago)...there was no doubt that one had "slipped" :roll:
 ...was DD'ing the ol girl and working nights, battling a leaky top radiator tank in the winter (so I just kept putting it off and adding water).  Leaned the mix out enough that one of our rare TX freezes froze up all the water in the head.  Jumped in, hit the key and WHAP!  BLAM! BLAM!  Seperated the the pulley right off the crank...water pump didn't budge a bit (frozen solid).  Could still pick up used balancers cheap then (12 or so years ago)...there was no doubt that one had "slipped" :roll:  {including a lengthy sabbatical]
Frankenstang":r449foug said:......
Kinda makes me wanna hear the 'rest of the story'but seriously, that's why I like combining the 'eyeballed' piston pinnacle while observing the valves......
   Pulled a spark plug and eyeballed the piston TDC while observing the valve action, still WAY out of whack. Made a piston stop to verify TDC more closely, everything was wrong
  My niece drove that car for several years; pity the poor slob who tries to pull that damper!
  My niece drove that car for several years; pity the poor slob who tries to pull that damper! just when you think you've heard 'em all
fordconvert":12k2min2 said:I have not seen them for a while. I think I bought one for my Buick in the late 80's.
