hey everyone,
i was wondering what you guys would advise on using with this cam,
here are sum specs:
its a wade
Profile No- 140
Lobe Lift- Ex .297
In .297
Timing Ad
Open Close- 74-41
40-70
Duration @.050- 238
238
Valve Clr- .013
.013
Valve Lift- .432
.432
Lobe Sep- 106
Rocker Ratio 1.5- Solid lifter, rough idle 3000 - 6500 +
i will be running a 2v head, but what should i do to it? double valve springs and all the usual stuff? also should i get a gear drive or should i just use a twin timgin chain?
any help appreciated
thanks
brendan
here are sum specs:
its a wade
Profile No- 140
Lobe Lift- Ex .297
In .297
Timing Ad
Open Close- 74-41
40-70
Duration @.050- 238
238
Valve Clr- .013
.013
Valve Lift- .432
.432
Lobe Sep- 106
thanks
brendan
