I got to looking at my H/W 2-bbl with Stovebolt adapter sitting on the Ford carb spacer plate, and said to myself..."Self, why not drill some holes in the 2-bbl adapter and mount it straight to the intake without that Ford spacer?"
So that's what I did. Bolt the two adapters together, then turn them over and use the intake manifold bolt holes in the Ford piece to locate the new holes (they'll end up about 3/8" offset from existing holes.).
Drill from the bottom, and: ta-dah! Actually, the holes are so close to the edge of the flange that I went ahead and cut them out into slots, then used some short bolts with washers to hold it all down. It's a bit tricky getting the bolts started, studs might make it easier.
The end result is a 2-bbl adapter sitting directly on the manifold, which lowers the carb, gains hood clearance, and makes it look more original (no more carb sitting way up in the air).
Pics to follow.
Pics to follow.
