PLX Air/Fuel Ratio Sensor Module w/ Sensor [PLX-SM-AFR] $185.25
PRODUCT DESCRIPTION
The PLX SM-AFR Air/Fuel Controller accurately measures the precise air/fuel ratio (AFR) of any internal combustion engine. Up to 32 SM-AFR modules can be daisy chained together in the iMFD system. SM-AFR can also be used as a stand alone unit capable of interfacing with 3rd party hardware. All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge.
SM-AFR utilizes the latest digital PID and DSP technologies to maximize o2 sensor reaction time and accuracy without compromising overshoot, and slow settling response time. This technology is coupled with advanced self sensor calibration circuitry and sensor soft start to both prolong the life of your oxygen sensor as well as eliminating any user intervention for manual sensor calibration. PLX widebands may be used and installed in your vehicle permanently.
NO SENSOR CALIBRATION IS REQUIRED! SIMPLY PLUG AND PLAY.
Technical Article: PLX Critical Response Technology
ANALOG OUTPUTS:
Wideband 0-5V analog linear output
Narrowband 0-1V analog output Replace your stock narrowband sensor
INCLUDED ITEMS:
SM-AFR main unit
Bosch LSU 4.2 wideband sensor
O2 sensor harness 10ft
4ft power wire with 2.1mm connector
4ft Analog wires and connector with 4 terminals
1ft Serial Cable
Termination jumper
Quick start guide
Affordable and accurate; Wideband AFR Sensor Module designed to work with DM-5 or DM-100.
