In my opinion, yes, it is worth doing; if you are paying someone else then be sure to get a "Not to exceed" quote, you may decide it isn't worth it.waldo786":210k9fts said:..... Engine will be otherwise stock. Is it it worth it?
David,CZLN6":38spyufo said:Howdy Waldo:
I'm in agreement with Joe. Know that the biggest return will be the work done within an inch either side of the valve seat- with the valve and valve seat most critical. The improvement will be avaiable and noticeable from idle to max rpm. A prioritized list of specifics to improve flow would be-
* A performance three angle valve job. A stock OEM head has a valve seat of one 45 degree angle.
* A 30 degree backcut on the upstream side of the intake valve.
* Blending the transition edge from as cast to machined in the valve pocket.
* Smoothing the combustion chambers and removing sharp edges.
* Removing casting flashing and irregularities from the ports.
* Rounding short turn radius'.
You may have noticed that I did not list opening and/or polishing the ports. This is the lowest priority and only useful in high rpm applications. Shaping to help flow, control heat, and support efficient combustion is the goal.
You said "a basic port job?' What does a basic port job entail?
That is what most head porters forget, VELOCITY.AzCoupe":21kl6swy said:I'm assuming a "Basic Port Job" is referring to the description on the CI website.
Our "Basic Port Job" includes a light clean up and flash removal, smoothing the combustion chambers, blending the transition from the valve seat into the port bowl area, as well as gasket port matching of both the intake (OZ and CI heads only) and exhaust ports. Emphasis is placed on velocity and how the air enters the combustion chamber, rather than simply increasing air flow. In my opinion, it's well worth a $100 bucks.
While dyno time is not cheap, it may answer a lot of questions. Can the stock log head be improved with the log still attached? If so how much? Is it worth the effort?In the near future, we're planning to test various cylinder heads (stock rebuild, our Standard and Performance rebuilds, and a 2V conversion) on a freshly rebuilt motor. I currently have both a 200ci and a 250ci at the machine shop, so I can use either one for testing? We were going to use a mild cam for our test, but maybe I need to reconsider and think about testing with a stock cam as well? The only problem is, it will more than double the amount of time required on the engine dyno, which isn't cheap.
This is another thing that needs a definitive answer. Does the port divider work as advertised? Is it worth the effort?We also hope to test a couple heads with, and without, a port divider. Personally, I think port dividers are a waste of money. However, that's just my opinion and I may be wrong. My head porter believes Ford intentionally designed the log head with Siamese ports, for two reasons. First to help scavenge the exhaust from the center two ports, and secondly to assist in cooling. Not to increase power..... As such, the installation of a port divider may be detrimental, rather than beneficial? However this is just an assumption. Do they really make a difference? We'll find out.....
Excellent topic.... very interesting.
Rbohm, you hit the nail on the head. Head porting alone rarely yields the same benefits as when done in conjunction with other mods. Porting complements and adds additional gains when done with other improvements, like larger valves, bigger cams, better induction, etc. The same holds true for the enthusiast looking to put a 4 bbl. carb and intake on a stock engine with no header and stock camshaft. He might see some gain, but not as much as if he had added supplementary components along with his intake and carb swap.rbohm":3l2aijg3 said:That is what most head porters forget, VELOCITY.
No worries.CNC-Dude":pxwxi0go said:Mike, I know that you know this, so don't think I am telling you what or how to do your thing. But, when comparing the gains from head to head with different valve sizes for instance, make sure you keep the combustion chamber sizes the same, so that a rise in compression from one head to the next wont skew your results, and the gains you see will be solely from the difference in valve size, and not other variables.
CNC-Dude":3qltm69u said:...... we saw absolutely no gain in HP whatsoever, not even 1 single HP of gain. It wasn't until we made changes in the camshaft deparment that we begin to see any benefits .....
