All Small Six Seat/bowl blending question
clochard68
Subscriber
Supporter 2021
Supporter 2022
Supporter 2023
I have a question regarding bowl blending on my small log cylinder head.
My car is just a weekend cruiser but with some simple upgrades (ignition, carburetor, header and exhaust, little higher compression). My machine shop put new hardened seats in my cylinder head and they did a three angle valve job (60°, 45°,30°). As you can see, there is a ridge (max. 0.04” wide) between the bowl and the base of the seat insert. Now I have two options for blending (and I sonic tested the head, I have enough material to do both variations) (see also picture attached):
A) I cut straight (90°) below the 60° angle and the blend it into the bowl (so the 4 angles would be 30°,45°,60°,90° and blending)
or
B) I make an 80° cut that cleans up the 60° angle and then blend it into the bowl. (here I would get rid of the 60° angle and replace it with the 80° angle. The 3 angles would be 30°,45°,80° and blending)
What would make more sense (A or B) for a cruiser car with a stock camshaft that is driven mostly in town, where torque matters?
I'm no expert but I would do B without removing the 60* . A Dremel with carbide bits will make quick work of it.
Thanks, but unfortunately it is not possible to move the seat angle outwards, I am limited by the valve size. So I cant leave the 60° and do the 80° because that would still leave a lip (although smaller, but still there).
You want to keep the 60 degree angle. It is important for low valve lift flow.
Did you do a 30 degree back cut on the valves?
Thank you, I guess then I will cut 90° below the seat insert and blend it in.
I plan on back cutting the intake valves 30°, but haven't done it yet. Would that change something on the seat angle design?
Short of putting new seats in with smaller ID, I would do "A" on the short side and leave the long side alone.
Only on the short side would mean around more or less a third of the total throat circumference (on the short side) or more or less half of the circumference (up to the long side on both sides)?
Since they left such a huge step in the head, you might want to ask how much they would charge to bowl cut it for you. Then all you might need to do is a very slight deburr with a cartridge roll to blend it.
It appears the chamber wall side is already at the 90 or "A" so follow around the short side (1/3 circumference) and end at the transition to the exhaust side of the intake port.
Thanks everyone for all the suggestions, I will keep the 60° and ask the machine shop what they can do with the bowl!
David Vizard has some interesting videos on porting and performance, the first one was on valve seat/throat. I think he said not to worry about the short side because because air velocity overshoots it to the far side, where you want to concentrate on your blending.
:eek:I'm almost embarrassed to admit that I know of this method, but here goes...Take an old long stem valve that fits your guide, cut the head off.
Chuck the stem in a drill and mount up a hole saw of the right diameter. Run it into the bowl. Instant throat porting
Maybe I will try it if everything else fails 😅
I have some Neway Cutters with round cutters, hopefully I can make a clean cut with them. I will try it after Christmas on the exhaust first and see how it works out.
