the 350 '7448' Holley is universally available and a good carb for tweaking a new build. Parts and upgrades are same as universal 4150 4 Bbl with plenty of info. Interestingly - the 500 CFM 2300 '4412' version is usually
less expensive , maybe more common?.
I've used 350 and 500 CFM 2300's on various small block six builds. 350 works well on mild builds but definitely more carb than most will ever need. Trying a 500 on a mild small six produced eye-watering rich conditions hard to remove. On a performance built 250 , the 500 was adequate but without intake mods don't see the point.
For best actual road
drivability if not performance, the
progressive 2 Bbl or
progressive multiple carbs' on a built small six should be considered. Weber and similar Holley/Weber progressive 2Bbl's are rated up through 300CFM but small primary adds MPG with better low throttle response and 'kick' when secondary opens.
practically - the later
cable over the valve cover Pedal setup used on Stang/Maverick sixes makes swapping carbs simpler.
- Adapters and tall carbs have air cleaner clearance problems on most cars.
- quality fuel pressure device recommended.
- mounting 2300's with fuel bowl directly above exh./Headers not recommended.
2 X 1 Adapters work fine for using different purpose carbs' on the small six but need much-mentioned mod/fab of intake 'manifold' to enable big CFM flow carbs... . Nicest 2 X 1 adapter found was from VI , well machined for function.
daily driver wagon has Maverick 170 / @9.5:1 SCR milled/worked '77 head / Headers / H-W 5200 (32/36) carb on $15 2X1 adapter / T5 / tube radio. Runn'n great over 10 years...
