Some things I've already done:
1-Flushed the system, i.e. block.
2-Started w/a new AL radiator, single row, worked okay (W/O AC ON) w/electric fan, then elec fan ate through the mount pads you place between the rad and the rad fins, and tore multiple holes in the AL RAD, due to vibration I'm sure.
3-got another original 6 cyl copper radiator larger than original NEW. This is the one now overheating while sitting in traffic in 85° weather, so CAL.
4-No rust build up in block or chips floating around in the cooling system, i.e. no blockage.
5-6 blade fan.
6-no shroud, I need one I know but don't know which ones will work?? (I ordered one from CJ Pony Parts & they never shipped it)
7- I installed the vintage air AC system last year and still can't use it.
8-Timing is correct but didn't check it a high RPM.
9-Mixture? Can't tell if its running too lean or not, ANY how to help here would be appreciated.
10- New water pump, new thermostat.
11-Petronics Elec ignition.
12-Engine needs a rebuild though, 10 mi/gal, blue smoke, oil fouled plugs. I sand blast the plugs every couple of months or so, etc.
My theory is to overkill w/cooling thus the 390 rad idea. I have not heard of anyone NOT having overheating issues with 6 w/AC, in fact I've never seen a six Mustang w/AC except mine. VERY frustrating.
Thanks very much for your thoughts but has anyone got a 200ci running cool with AC?
