Different PCV Size For Carb Spacer
kukm66
Post #1 by kukm66 » Mon Apr 12, 2010 7:15 pm
I have a 1 3/4" carb spacer for use with a Carter YF setup. This particualar spacer has a PCV snout that has a smaller diamerter hole for the nipple that inserts into it.
I have another one that has a larger hole for use with a 5/16" nipple which accepts the PCV hose setup.
I cannot find a nipple to insert into the snout and I do not want to take off the carb and spacer setup as it is nice and vacuum tight.
Has anyone seen a smaller type nipple on one of these spacers? Any ideas on what to improvise since finding one may be a challenge.
This is yet another dumb change made by Ford to drive us nuts.
1964 Falcon Futura Convertible
1964 Ranchero
kukm66
Re: Different PCV Size For Carb Spacer
Post #2 by kukm66 » Tue Apr 13, 2010 7:56 pm
Well, I found that by removing the nipple from the fuel pump, it fit into the spaccer plate with a little tapping.
I am still bewidered by the difference in the hole sizes for those spacer plates.
1964 Ranchero
Rinke
Post #3 by Rinke » Fri Apr 16, 2010 9:05 am
Hi.
I had the same problem with my aftermarket spacer.
I just went to the local hardware store and got me a nice fitting metal garden or barbeque gas hose fitting.
Problem solved..
Rinke
64 Falcon Station Deluxe
3 on the tree
170
3.50:1 rear end
Been collecting dust & adding rust for 30 years
Goal: to keep it all working from okt 2008 till all eternity
Users browsing this forum: No registered users and 28 guests
