Hello all,
Finally getting back together my girlfriend's '78 200ci to prep it for installation into her base model '67 Mustang.
Just had the block decked to zero at the machine shop, and now comes cam selection.
We're using the stock '78 head, ported and polished, and aiming for somewhere on the lower end of 9.5:1 compression.
We have a 4cyl T5 installed at the moment, and we plan on running an 8.8" rear end with either a 3.55:1 or 3.73:1 ratio, though right now we have the stock 7.25" in there, and I'm unsure of the rear ratio right now - either 3.00:1 or 3.20:1 is likely.
At some point I'd like to put CI's long tube dual outlet header on there with a couple of side exits, but for now the funds only permit usage of a stock log exhaust manifold. For the moment, we're stuck with her crappy, worn out Autolite 1100, and we haven't decided on a new carb yet because the funds aren't allowing for that, and because frankly we're nowhere close to that stage just yet. I was thinking a 2100 series, but that's up in the air. When it comes time to choose what we've already done with the motor will help decide what carburetor we should go with. Right now we want to get the motor itself together. We have a DSII dizzy that came on the '78 motor too, so I just need to pick up a module and do the wiring (once we get a non-SCV carb) and she'll have DuraSpark II also. Right now we're using an Ignitor II that I'm less than impressed with.
It's gonna be a fair weather daily driver for her, and probably won't ever see a track, but we want as much oomph as we can get without making daily driveability a chore and without vastly breaking the bank. To be honest I drive the car much harder than she does, but I'm sure she'll be into the gas some more when it has a motor that runs right in it. It has been an around-town car up until now, but honestly that's just been because we can't trust it on the highway. Once it's more reliable I could see her taking it farther distances. The overdrive transmission will only help that.
I was eyeballing both the CSC 264/274 110* and 112* because I think she'd be very giddy about her car having a somewhat lopey idle, and 1600-5400rpm seems like a good operating range for such a car with such gears - but if I'm making a poor choice here, please correct me. Also, the only difference between the two aforementioned cams is that I can see is the lobe centers. Can someone explain to me in layman's terms what a lobe center difference of 110* vs 112* is? That means the cam timing is a bit farther advanced on the 112*, right? What's that translate to in real world performance terms?
So basically what I'm looking at is:
- base model '67 Mustang, curb weight somewhere around 2500lbs?
- 1978 200ci motor, stock head ported and polished, zero deck height, target compression 9:1-9.5:1
- 4 cylinder T5 swapped.
- 3.55:1-3.73:1 rear ratio planned
- long tube dual outlet header planned
- '78 DSII planned
- Carburetor choice is still wide open
- Probably won't see a track, but we want the most bang for our buck regardless.
- MUST be hydraulic
I'm not against Comp Cams/Isky/Schneider/Clifford either... I really just want what's best for my girlfriend's car and I don't want to make the wrong choice here. I ask that any recommendations anyone makes please keep our future plans in mind, because the concept of gaining more seat-of-the-pants power as we get closer to the cam's ideal components (i.e. adding a header, numerically higher rear gears, etc.). Price is not an issue in cam selection at the moment because I'm getting it for her for Christmas, and I am mostly concerned with her getting the best camshaft she can get.
Thanks in advance for the help, guys!
- '78 DSII planned
- MUST be hydraulic
